Auto-Path
I have been experiencing a problem when trying to generate a path from a curve using the constant spacing option. I can simply click "Continue" and I can proceed with the operation but that button is contained within a error box that States "Index was outside the bounds of the Array." Is there a way that I can quickly fix this problem?
What version of RobotStudio are you using?
I am currently using Robot Studio 5.14.03. I had the same issue with 5.14.02 but I can't remember if it started with 5.14.01. It seems like 5.13 didn't have this issue.
i am a user of 5.13 and indeed i dont experience the issue you mentioned. i think it had got to do with the versions0
[quote]
of the Array." Is there a way that I can quickly fix this problem?[/quote]
Please upload the part that causes the problem, including the settings used.
Henrik Berlin2012-06-15 06:33:00Henrik Berlin
I am no longer having the issue. It may have been a bug in .02 that was fixed in .03. Thanks for the support.0
Great that you have already fixed the problem. Now I don't have anything to suggest.
- 350 IRC5
- 848 RAPID Programming
- 21 AppStudio
