Impossible to open a station file
Dear all,
I'm currently working on a station, that I built from this morning. I've done a lot of work, everthing was ok, but I had a crash with RS a few minutes ago. No response from the system after I tried to relocate some robtargets. I just saved my station before the crash.
I had to close RS from the Windows taskmanager.
And I can't open anymore my station.
I have this error in the log :
"RobotStudio .NET exception: L'index (de base zAcro) doit A?tre supAcrieur ou Acgal A? zAcro et infAcrieur A? la taille de la liste des arguments.
Base exception: FormatException
   A? System.Text.StringBuilder.AppendFormat(IFormatProvider provider, String format, Object[] args)
   A? System.String.Format(IFormatProvider provider, String format, Object[] args)
   A? System.String.Format(String format, Object arg0)
   A? ABBInternal.FileCommands.FileCommandServices.Project_ProjectFileLocked(Object sender, ProjectFileLockedEventArgs e)
   A? ABB.Robotics.RobotStudio.Project.RaiseProjectFileLocked(String fileName, Boolean& cancel)
   A? RobotStudio.API.Persistence.PimDocument.InternalLoad(String fileName, String docType, Boolean readOnly, Nullable`1 requiredGuid)
   A? RobotStudio.API.Persistence.PimDocument.Load(String fileName, String docType, Boolean readOnly, Boolean allowExisting, Nullable`1 requiredGuid, ProgressNotification progressDelegate, Double progressStart, Double progressEnd)
   A? ABB.Robotics.RobotStudio.Stations.Station.Load(String fileName, Boolean asReadOnly, ProgressNotification progressDelegate, FileNotFoundNotification fileNotFoundDelegate, Boolean loadGeometry)
   A? ABBInternal.FileCommands.FileCommandServices.OpenStation(String fileName, Boolean loadGeometry)
   A? ABBInternal.FileCommands.OpenStationCommandHandler.OpenStationCommandHandler_ExecuteCommand(Object sender, ExecuteCommandEventArgs e)
   A? ABB.Robotics.RobotStudio.Environment.CommandBarButton.RaiseExecuteCommand(ExecuteCommandReason reason)"
Sorry, it's in french.
Could somebody help me, my work is very urgent, I'm at my customer, and it's the complete crisis here !!
HELP !!!
Luxrobotic2012-08-29 15:25:31
Regards
Cornet Raymond
Manager
+352 621 354 570
raymond.cornet@luxrobotic.com
http://www.luxrobotic.com
HP ZBook Fury 16 G11
