Home position
Here is our user mode home position routine...
Before home position changed,
do03_RobHome signal is well activated.
However, after change pHome by jogging,
do03_RobHome signal is not set even though Rotot is at pHome position...
What is problem...? please help me..
MODULE user (SYSMODULE)
 ! Predefined user data
 ! Declaration of numeric registers reg1...reg5
 VAR num reg1 := 0;
 VAR num reg2 := 0;
 VAR num reg3 := 0;
 VAR num reg4 := 0;
 VAR num reg5 := 0;
 ! Declaration of stopwatch clock1
 VAR clock clock1;
 VAR pos pHomepos:=[0,0,0];
 VAR shapedata HomeZoneShape;
 VAR wzstationary HomeData;
 PROC Zones()
    !Robot Home zone Check:
    pHomepos:=pHome.trans;
    WZSphDefInside,HomeZoneShape,pHomepos,10;
    WZDOSetStat, HomeDataInside, HomeZoneShape, do03_RobHome, 1;
ENDMODULE
  • What do you mean by change home position? Did you created new home position or you just jogged robot out of the home position?
    I dont understand the question clearly. And where did you call your procedure Zones() in the main program?
  • You have to warmstart the robot control once you change your home position, so your Zone() procedure will run. The zone procedure should be connected to the power-on event and can only be run once to set your world zones - warmstart teh controller or cycle power to it to establish the new home position.
    Thomas H. Johnston
    PACs Application Engineer
  • Thank you....
    It works...
    I am a beginner. So it is very helpful of your reply.. thanks.
