Create Arc Process [ArcWelding PowerPac]
I have recently loaded RS 5.14.01 and Arc Power Pack 5.14.0. I am having problems creating new processes/welds. When I try to import ArcDefault I get a message that says:
ProcessTemplate: ArcDefault_2_ProcStart
Instruction: ArcLStart
Not present in the Station
What do I need to do to be able to add new Weld processes? Thanks.
Hello,Are you missing the Arc option?BR / Henrik
Kga Offline Center www.kgaofflinecenter.se
Offlineprogramming and simulation in RobotStudio and ArcWeld PowerPac0 -
The Arc Option is check off with additonal Arc Options 650-5 and 652-10
I believe that I have not generated the system correctly for this station I am trying to generate a system from the layout for this station and I can't find the media pool. Am I doing something wrong
Your image is too small, it's not clear.0
<a href="http://www.thepaintzoomreviews.biz/best-spray-paint-equipment.html">click here for</a> paint zoom spray'0
- 858 RAPID Programming
