Process Timer
I had a question regarding the Process Timer.
Can the Process Timer somehow be reset from the event table or some other means involving an event or I/O in the simulation?
Regards,
C
  • Hi,
    No you can not reset the process timer. But in RobotStudio 5.15 (which will be released now in October) you can add one ore more "Stop Watches" that can be start/stopped by an I/O event for example. They can also be triggered with the "target changed event".
    ABB Robotics
  • Thank you Anders
    Regards,
    C
