Formula(q1, q2,q3, q4) to (Yaw, Pitch, Roll)
I need to translate between the (q1, q2,q3, q4) and (Yaw, Pitch, Roll), could anyboday share the the formula of it.
As I learned ABB interal use the Excel with fromula.
Br,
Wilson
Hi,There are several on-line convertors - if you do a serach for "quaternion converter".You need to check the results as the order of the Euler angle input on some is not the same as the 'ABB" way (you just need to swap the order you enter the angles to get it right).Hope this helpsGraemegraemepaulin2012-10-09 22:01:240
Hi Graeme,Thanks for your support.It is ok to find the convertor online. but it will be better if there is some VBA in Excel, we could utilise it whenever we want.Br,Wilson0 -
Search for the software named TRAFO
Or there is rapid function aswell
OrientZYX
Cheers
- 345 IRC5
- 73 OmniCore
- 843 RAPID Programming
- 20 AppStudio
