Setting UP PROFINET SLAVE
Nata_lia
Hi All,
I need to set up the PROFINET Salve for ABB robot, Please someone provide me some instructions, ideas or step by step manual for it. Thank you very much.
Hello,Setting up a Profinet slave, while straightforward, is a long process and can't be all copied here in the forum.First check which Profinet Slave option you have, there are a number:Option 888-1 Profinet I/O m/s HW -- hardware option for a DSQC 678 in the PCI slotOption 888-2 Profinet I/O m/s SW -- software option for Profinet Master or Slave over the LAN or with other Hardware Option Ethernet BoardOption 888-3 Profinet I/O Slave -- software option for Profinet Slave over the LAN or Ethernt Board hw optionOption 840-3 Profinet I/O -- Profinet Fieldbus Adapter in the USB slotFrom this, setting up is described in the manuals from the Documentation DVD under Application Manuals --> Fieldbus Options.Kind Regards,Steve0
Thanks Steve.
Hi Steve, I have OPTION 881-1 PROFINET I/O m/s
I set up my IO signals and can use them in my rapid code.
Now I am trying to connect the PLC to the PCI Ethernet slots. To get the communication setup with the PLC do I need to set up or configure IP address somewhere? or I can just plug in the PLC to the etehrnet port in the PCI board.
Thanks a lot
- 341 IRC5
- 68 OmniCore
- 839 RAPID Programming
- 18 AppStudio
