visualize motion if I keep moving the mouse
Hi there,
I'm working on optimizing a path. When the robot moves along some robTaregt points using "jumpto", I only can visualize the robot's motion if I keep moving the mouse pointer on the robotstudio "view" window. Is there a way to fix this or do it automatically, so I can my motion behavior?
khmgarbia2012-10-18 17:11:33
Thanks,
Khaled
Khaled
Can you give us a codesnippet of what you are running?But if I would guess then what you need is probably to add this when necessary:
Station.UpdateGraphics();John
Developer Center0 -
Thanks John! You solved my problem by just adding "Station.UpdateGraphics();" after the "JumTo" line.Best!Thanks,
Khaled0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
