Change fence size
Tami91
Hey,
I want to rebuilt one robot cell in my Robotstudio-programm. I have already found the components like the pallet, the fences and so on but they havenA't the right size.
Is it possible to change the dimensions of the fence? And how can I do that?
I hope you can help me
Hi,You can not change the dimensions of the fences installed with RobotStudio. But on RobotApps you will find an AddIn called "Fence Creator" and a Smart Component "Parametric Fence ver.3", which may create fences in different dimensions.Best regards,
Thanks for the help
Is there such an app for any other equipment?
Tamara Heid0 -
Hi everybody
i Unzip it directly in "C:Program Files ABB Industrial ITRobotics ITRobotStudio 5.14BinAddins" folder, Then i start robotstudio got a error messageTom And Jerry0 -
Hi, BerlinThank You a lot, It works!Tom And Jerry0
I have a same problem but the solution link does not work.
Can you help me how can i use/install this robot apps: parametric fence and smart component fence.
I know this is smart component but i can't import this in rs.
Thank You,
- 341 IRC5
- 69 OmniCore
- 840 RAPID Programming
- 19 AppStudio
