Sync to VC
Klaus
After som move along path i get a lot of RsTempModule in RS online.
I have now over 40 and i can only delete one of the time.
Does anyone have an idear to not get them
Best regards Klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
Klaus Soenderhegn
www.cadalysator.dk
Normally should the RsTempModule be deleted automatically after each Move Along Path.
If you have over 40 TempModules something is wrong with your
VirtualController. I recommend that you cold start your controller and
see if that helps (but be aware of that all your programs will be lost
in the controller).
Another way is to setup a simulation instead of using Move Along Path.
[QUOTE=Anders S]Normally should the RsTempModule be deleted automatically after each Move Along Path.
If you have over 40 TempModules something is wrong with your VirtualController. I recommend that you cold start your controller and see if that helps (but be aware of that all your programs will be lost in the controller).
[/QUOTE]I have exported the program and deleted al the tmpmodul i the directory and then loed the program and now i works.
Thanks for your help
Best Regards
Klaus Soenderhegn
www.cadalysator.dk0
- 5.4K RobotStudio
- 383 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 733 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
