Check Position after Stop
Moved to RobotWare forum.
I'm also interested in this. Maybe this thread [1] can help you (and me :-D) but I haven't tried yet.0
Good morning to Everybody,
I have tried this procedure inserted in the Main:PROC StopCiclo()
!--- ROUTINE DI STOP CICLO TRAMITE EVENT -----
!-------- Gestito con Event STOP Controller --------
! Memorizza Posizione in Giunti
! Solo in ModalitA? AUTO
TEST OpMode()
CASE OP_Auto:
StopMove;
jStop := CJointT();
ENDTEST
ENDPROCRecalling from "Control panel Configuration Controller Event Routine Stop & QStop" the aforesaid Routine, succeeds in memorizing the position of the robot in the moment in which he stops.
To check to the I Start or Reboot of the robot that the position has remained the same one to the moment in which is stopped, call from "Control panel Configuration Controller Event Routine Start & Restart" the following procedure:PROC RestartCiclo()
VAR jointtarget jActPos;
!-- ROUTINE DI RESTART CICLO TRAMITE EVENT --
!------ Gestito con Event RESTART Controller ------
Evento := TRUE;
CheckActualPos;
IF DI_PLC_Richiesta_Aborto_Ciclo = 1 THEN
StopMove;
ClearPath;
StartMove;
ExitCycle;
ELSE
StartMove;
ENDIF
where the routine "CheckActualPos" it is the following
PROC CheckActualPos()
IF DOutput(DO10_1) = 0 AND DOutput(DO10_2) = 0 THEN
TEST OpMode()
CASE OP_Auto:
! Recupera posizione attuale in Giunti
jActPos:= CJointT();
TPWrite "entra";
IF (Abs(jActPos.robax.rax_1) - Abs(jStop.robax.rax_1)) > 0.2 THEN
GOTO ErroreAsse;
ENDIF
IF (Abs(jActPos.robax.rax_2) - Abs(jStop.robax.rax_2)) > 0.2 THEN
GOTO ErroreAsse;
ENDIF
IF (Abs(jActPos.robax.rax_3) - Abs(jStop.robax.rax_3)) > 0.2 THEN
GOTO ErroreAsse;
ENDIF
IF Abs(jActPos.robax.rax_4) - Abs(jStop.robax.rax_4) > 0.2 THEN
GOTO ErroreAsse;
ENDIF
IF Abs(jActPos.robax.rax_5) - Abs(jStop.robax.rax_5) > 0.2 THEN
GOTO ErroreAsse;
ENDIF
IF Abs(jActPos.robax.rax_6) - Abs(jStop.robax.rax_6) > 0.2 THEN
GOTO ErroreAsse;
ELSE
GOTO NoErrore;
ENDIF
ErroreAsse:
Esito := GestioneErrori(6);
ExitCycle;
NoErrore:
ENDTEST
ENDIF
Verifying to move only also in manual after the Stop an axle more of 0.2, doesn't go to error!!!
Does someone know how to tell me where I am being wrong?
Thanks to Everybody.0
- 361 IRC5
- 78 OmniCore
- 852 RAPID Programming
- 30 AppStudio
