Check Position after Stop
Good Morning,
I should like to check the Stop Position of the robot before to restart him in Auto ( After Emergency or if I switch in manual when the robot cycle running and someone move the robot in manual ). How can I do ?
  • Moved to RobotWare forum.
    ABB
  • I'm also interested in this. Maybe this thread [1] can help you (and me :-D) but I haven't tried yet.
  • Good morning to Everybody,
    I have tried this procedure inserted in the Main:
     PROC StopCiclo()
      !--- ROUTINE DI STOP CICLO TRAMITE EVENT -----
      !-------- Gestito con Event STOP Controller --------
      ! Memorizza Posizione in Giunti
      ! Solo in ModalitA? AUTO
      TEST OpMode()
      CASE OP_Auto:
       StopMove;
       jStop := CJointT();
      ENDTEST
    Recalling from "Control panel Configuration Controller Event Routine Stop & QStop" the aforesaid Routine, succeeds in memorizing the position of the robot in the moment in which he stops.
    To check to the I Start or Reboot of the robot that the position has remained the same one to the moment in which is stopped, call from "Control panel Configuration Controller Event Routine Start & Restart" the following procedure:
     PROC RestartCiclo()
      VAR jointtarget jActPos;
      !-- ROUTINE DI RESTART CICLO TRAMITE EVENT --
      !------ Gestito con Event RESTART Controller ------
      Evento := TRUE;
      CheckActualPos;
      IF DI_PLC_Richiesta_Aborto_Ciclo = 1 THEN
       StopMove;
       ClearPath;
       StartMove;
       ExitCycle;
      ELSE
       StartMove;
      ENDIF
    where the routine "CheckActualPos" it is the following
     PROC CheckActualPos()
      IF DOutput(DO10_1) = 0 AND DOutput(DO10_2) = 0 THEN
       TEST OpMode()
       CASE OP_Auto:
        ! Recupera posizione attuale in Giunti
        jActPos:= CJointT();
        TPWrite "entra";
        IF (Abs(jActPos.robax.rax_1) - Abs(jStop.robax.rax_1)) > 0.2 THEN
         GOTO ErroreAsse;
        ENDIF
        IF (Abs(jActPos.robax.rax_2) - Abs(jStop.robax.rax_2)) > 0.2 THEN
         GOTO ErroreAsse;
        ENDIF
        IF (Abs(jActPos.robax.rax_3) - Abs(jStop.robax.rax_3)) > 0.2 THEN
         GOTO ErroreAsse;
        ENDIF
        IF Abs(jActPos.robax.rax_4) - Abs(jStop.robax.rax_4) > 0.2 THEN
         GOTO ErroreAsse;
        ENDIF
        IF Abs(jActPos.robax.rax_5) - Abs(jStop.robax.rax_5) > 0.2 THEN
         GOTO ErroreAsse;
        ENDIF
        IF Abs(jActPos.robax.rax_6) - Abs(jStop.robax.rax_6) > 0.2 THEN
         GOTO ErroreAsse;
        ELSE
         GOTO NoErrore;
        ENDIF
        ErroreAsse:
        Esito := GestioneErrori(6);
        ExitCycle;
        NoErrore:
       ENDTEST
      ENDIF
    Verifying to move only also in manual after the Stop an axle more of 0.2, doesn't go to error!!!
    Does someone know how to tell me where I am being wrong?
    Thanks to Everybody.
