SafeMove on 3d model
JarkkoL
Hello abb specialists!
Is there a posibility to check safemove configurations on simulation?
Example i'm now using Safe Tool Zone areas, and robot is not at 90 degree angle against of safety fences. It's more like 30 degrees. So define of safety areas are quite difficult (when using of 500mm long tool).
It would be great to run programs on offline and check where robot goes outside of safety area, and how much?
Or does i have to build safe areas & tool definition by my own to simulation?
JarkkoL2012-11-06 08:17:13
Dear robot studio developers,seems that there's no answer for my question..When working with new version of robotstudio, keep simulation of safemove areas on your minds.On yellow robot's it's allready possible, why not on abb
br. Jarkko0 -
Dear Jarkko,
just found your request. Are you still working with ABB robots or did you go for the yellow ones
regards
regards
Christian1
