Speed Robot
Good morning to everybody,
does someone know how to tell me which parameter it returns me, in real time, the speed done plan on the flexpendant?
  • Hi
    You can define a system output for the TCP speed
    EIO.cfg
    SYSSIG_OUT:
      -Status "TCPSpeed" -Signal "aoTcpSpeed" -Arg1 "ROB_1"
    For output on the flexpendant you could use a time triggered interrupt and give out the value with:
    TPErase;
    TPWrite "TCP-speed: "+NumToStr(AOutput(aoTcpSpeed)*1000,0)+" mm/s";
    I hope it works then I didn't test it.
    Best regards
    Marcel
  • Thanks thousand,
    but in reality what I would like to do is to modify the speed of the in operation Tcp of the speed planned on the Flexpendant, this to have a speed +o - constant of some movements of mine even if they vary the speed from Flexpendant.
    For example planning the speed vProva.v_tcp:=1000, I would like that the time employed by the robot by the punto1 to the punto2 both around the same one, both to 25%, and to 100%.
    I have made different tests, but it seems that I/you/he/she always command and however the speed of the FlexPendant ( vProva.v_tcp:=1000 to 100% have tried with vProva.v_tcp:=5000 to 20%, but the second part is slow more and more).
    Reassuming, do you know how to tell me if a way exists for getting a constant speed varying the percentage from FlexPendant?
    In advance thanking all, I wish You Good Day.
