Service port connection 5.15.0
At 2 robots I have upgraded the system to RW 5.15.0  I have opened RobotStudio and connected to the robots. I have been logged in as a different user (Programmer) with all rights. The robots can be seen in the list. When I now disconnect and connect again to the service port the robot stops program execution automaticly at the moment that the robot connection is established.
I noticed that this is only happening when I have been logged in as a different user. When logged in as default user it is not happening.
A bug in RW 5.15? Why is the robot stopped? This situation is not occuring in previous versions. Same situation occurs at both robots.
What can I do that the robots do not stop when connecting to the service port?
  • Thanks for notifying us about this problem. We will investigate it.
    ABB
  • Do you still have RobotStudio 5.14.0x on your PC? If so,  does the robot behave the same way when you repeat the procedure with RobotStudio 5.14.0x and RobotWare 5.15?
    ABB
  • Henrik,
    I also have RS 5.14.3 on my laptop. I did several test. The mentioned stopping of the program does not happen in 5.14.  I wrote before that it is only happening when logged in as different user. but the stopping also happens at the default user.
    Stopping of the program also happens when starting to monitor the main program first time.
    When closing/opening the program while RS is still active does not stop it again. So, only after RS5.15 is started 1st time and opening a module to monitor. When I close the monitoring and start again the stopping of the robot is not happening.
