Reehand move do not work on wobj and tools
Klaus
I older versions of RS i used to move wobj and tools with freehand. Now freehand move and rotation is disabled as soon i select the Path&Targets tab in the browser.
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
Klaus Soenderhegn
www.cadalysator.dk
You need to help me a bit. I am able to free-hand move workobjects but not tooldata. I get the same behavior for both 5.14.03 and 5.15.
The button is disabled as soon i click on targets&pathBest Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
Best Regards
Klaus Soenderhegn
Hi Klaus,
You cannot freehand move a tooldata that is moved by the robot. That is not possible in 5.14.03 either. However, you can free-hand move stationary tooldata. In order to do that you need to activate selection level "Target / Frame".
Super.I haven't work with stationary tools i the last versions of RS.ThanksBest Regards
Klaus Soenderhegn
www.cadalysator.dk0
- 364 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 32 AppStudio
