can't select the mechanisms created by wizard
Hi,everybody
i import a spot gun and define it as a mechanisms by using "modeling--create mechanisms", the mechanism created can be jogged use "joint jog", after mounted the gun to a robot. i want to create a system by "create system from layout", but when i do the work step by step, i can't select the spot gun i created this means it can't be configured as an external axis in the system. how to slove the probelm?
Tom And Jerry
System From Layout does not support configuration of spot guns. You need to configure it manually. After you've started a system with the appropriate RobotWare option for spot welding, you need to manually add the configuration file for the spot gun, and then point out the mechanism when RobotStudio asks for the mechanism corresponding to the external axis.
Dear HenrikThank you i got itTom And Jerry0
