Function calling
Hello, I am a beginner in programming.I try to make procedure with parametr VAR or INOUT and compiler write me error. I think, that calling procedure with VAR or INOUT is something as pointer in language C/C++. For example:
MODULE A PROC routine(VAR num u)
PROC main()
  VAR num x;
   routine(x);
ENDMODULEAnd compiler write: Argument error(124): Argument for 'VAR' parameter x is not variable reference or is read only
Thank you for your advice
  • Try this instead:
    [CODE]MODULE A
        PROC routine(INOUT num u)
            u:=2*u;
        PROC main()
            VAR num x:=1;
            TPWrite "Before routine: x = "Num:=x;
            routine x;
            TPWrite "After routine:  x = "Num:=x;
    ENDMODULE[/CODE]
    You can see the result in the Operator panel below:
    ABB
  • The RAPID Overview manual contains a description of INOUT, see
    http://www.scribd.com/doc/71173119/Rapid-Overview-Manual#page=112
    ABB
  • The reason you received the above message is because "routine(x)" implies a functin with a return value - the correct use of your format is
    x:=routine(x); where routine is defined as a funtion with a return value.
        FUNC num routine(num u)
            RETURN 2*u;
        ENDFUNC
    The instruction call syntax when passing variables or parameters is "routine x;" without ()
    functin call syntax is "num:=routine(num);". with ()
    Whenever you use the parentheses () RAPID interprets it as passing parameters to a function that will return a value.
    To understand the difference please read the Introduction to RAPID section
    "RAPID instructions and functions"
    A RAPID function is similar to an instruction but returns a value
    Since the function returns a value, the result of the function can be assigned to a variable. The arguments in a function call are written inside parenthesis and are separated with commas.
    An instruction call looks like a procedure call with the instruction name followed by argument values not enclosed in parnthesis.
    Hope this helps...
    Thomas H. Johnston
    PACs Application Engineer
