PC Interface function at the IRC5
shcho
I'm going to connect to Webware server, So included PC interface option to the IRC5 controller. But I can't find Application Portocols manu on TPU monitor.
Please let me know how can I LAN setting. Please refer to the attached files.
Robot Model: IRB340 PickMaster
Controller: IRC5
RW Ver.: 5.06.0.0143
2006-03-29_110900_S3700003.zipshcho2006-3-29 11:12:44
Controller: IRC5
There aren't any settings to configure for PC Interface, you just need to set your IP address.
To set the IP address, you must X-Start your controller into the boot loader application and use the Settings menu to either set it up to use DHCP or to specify a static IP address.
Russell Drown0 -
Just a small clarification for other readers.
To connect to WebWare Server/SDK you need to have a robotware option.
On S4C+ this is FactoryWare Interface.
On IRC5 this is PC Interface.S4C+ with FactoryWare Interface has Application Protocols that need to be properly set up as per the manual.
IRC5 with PC Interface is preconfigured and thus requires no action.
John
Developer Center0
