ABB OPC server
szily85
Hey there,
I`d need some help about ABB OPC server.
I have a robot program and I would like to have a shared variable, which I can write from a NI LabView program. (I have a vision system working in LB). I need to transfer some data to the robot through OPC server.
I have a variable like this:
PERS num weld_x;
and I can`t write this, BUT I can read a same one to Labview.
So the question is, this is the correct variable type or not?
Why I can`t write data to this var?
I`m trying also with the Matricon OPC explorer, and nothing.
Can someone tell me something about this, or at least some path on internet where I can get some manual for the OPC server.
Szilard
Regards Szily
Hi Szilard,Please go through the attached document and let us know if it resolves your problem or not.Regards,Alok
Thank you very much, it worked
Much much greatings
Regards Szily0 -
Sometimes you can`t see the forest from the wood
Really appreciate your help, thanks a lot
Regards Szily0
- 361 IRC5
- 79 OmniCore
- 853 RAPID Programming
- 30 AppStudio
