build floppy disks for a S4C controller
dealsaaa
I have a key disk for a IRB 6400 S4C 3.0controller M97. Program No 3HAB2390-1/47.
How can I create/generate the rest of disks? I tried with Robotware 4.0 but it does not recognize the key disk.
Thank you,
dealsaaa
dealsaaa
HiRobotWare 4.0 is just for S4C+ controllers (totally different hardware than S4C)For S4C RobotWare 3.0 you need the RobotWare disks to boot a system.You should ask your sales person for the boot disks.Per Svensson
Consat Engineering0 -
Thank you Per,For a S4C+ we are using RW4.0. What software is need it to create the boot disks for S4C controllers and if it is available for us integrators? Of corse having a key disk.Thank you,dealsaaadealsaaa0
HiI was looking in my file archive and found a zip file of 3.0 boot discs with Program no 3HAB2376-1/47. If you give me your email I can send it to you so you can give it a try.If you are an integrator I think you should be able to download it from the partner website but you need a login for that so contact your ABB sales person.Per Svensson
Hi Per,my email address is: dealsaaa@gmail.com.Could you pleaase email me files and I try them.Thanks again,Alexdealsaaa0
hi
i am having same problem in my plant .so can u send the 3.0 boot discs with Program no 3HAB2376-1/47 to my emailThis is my email id : d_gobi88@rediffmail.com0 -
I will send it later this afternoon europen time.Per Svensson
HiUnfortunally all the baseware versions in my archive was lost in an harddrive crasch. I may have a backup on a dvd but it will take some time to find it, and now it's Christmas time so I think you better get in contact with ABB.Per Svensson
hiThankyou for reply .no problem i will contact abb personandMarry Christmas0
HI Folks
If possible we are looking for programme discs for a customer’s ABB- 640M200 robot
can anyone help?
Is that supposed to be 6400 M2000? Do you have the keystring or a backup?Lee Justice0
