"Select RobotWare release for your system." ?
ct8356
I recently downloaded the 30 day trial version RobotStudio 5.15. When I try to add a template system, a window pops up that says "Select the RobotWare release for your system", and I don't know what to select. If I click cancel, it says "The system could not be created because there is no RobotWare release defined." How do I proceed?
Thanks in advance for your help.
Ahah, I found the answer here:0
