Impossible to open my station
Luxrobotic
Hi everybody,
I have a big issue with the station I'm workoing on.
I saved and closed it yesterday evening without any problem. This morning, I tried to open it , and it's impossble.
I've got this error message :
I'm using RS 5.14.03 because I use KMT Powerpac, I tried to open it with RS 5.15, but no way too.
I didn't saved my program module, so I may loose 4 hours of work !!
This is not the first time I have such problem, sometimes I succeed to open and save it with RS 5.15, but not this time.
Regards
Cornet Raymond
Manager
LUXROBOTIC programming Sàrl
+352 621 354 570
raymond.cornet@luxrobotic.com
http://www.luxrobotic.com
PC HP ZBook 17 G3
intel Core i7 6700HQ 2.59 GHz
RAM 16GB
HDD 1TB
NVIDIA Quadro M1000M
Cornet Raymond
Manager
+352 621 354 570
PC HP ZBook 17 G3
RAM 16GB
HDD 1TB
Hi everybody,
Before, I only tried to open it with RS 5.14.03 and RS 5.15 (64 bits). Now I succeed with RS 5.15.
I save my modules and the station with this release, but I still can't open the station with RS 5.14.03.
Regards
Cornet Raymond
Manager
+352 621 354 570
PC HP ZBook 17 G3
RAM 16GB
HDD 1TB
NVIDIA Quadro M1000M0 -
Hi,Did you try to save your station from RobotStudio 5.15 using "Save As" and a new file name?Henrik Berlin
Hello Henrik,
I did it, it was ok, but I still have some other issue:
API error, with impossibility to save the station.
I think there is a link with the geometries I load in my station.
There is a lot of geometries of different oarts to program. I'm now trying with less parts in my station, after a few hours, it seems better. But I need to try longer.
Thanks a lot
Regards
Cornet Raymond
Manager
+352 621 354 570
PC HP ZBook 17 G3
RAM 16GB
HDD 1TB
Regards
Cornet Raymond
Manager
+352 621 354 570
PC HP ZBook 17 G3
RAM 16GB
HDD 1TB
I worked one hour without problem, an now, I've got the same issue when I want to save.
I open it once again, without closing RS. I've got another error message:
I closed the dialog box, RS bugged.
I restart RS, and open the station. It's ok now.
Luxrobotic2013-01-02 14:16:44Regards
Cornet Raymond
Manager
+352 621 354 570
PC HP ZBook 17 G3
RAM 16GB
HDD 1TB
Your current problem seems to be related to memory. Are you using a very large station?To reduce station size you can use "Remove Geometry" on parts for which do not need to use AutoPath or SnapMode.The problem will be resolved when KMT PowerPac comes in a version that supports RobotStudio 5.15 64.bit. Then you will not be limited by lack of memory (assuming your PC has sufficient).Henrik Berlin
ABB0
- 344 IRC5
- 70 OmniCore
- 842 RAPID Programming
- 19 AppStudio
