Robot Acceleration Switching in Short Time Frame
I am working on ABB IRB 140.
For my application I need to accelerate the robot with 9500 mm/sec^2 for 0.1 sec and then with 12000 mm/sec^2 for next 0.1 sec and then decelerate it with 19500 mm/sec^2 for next 0.1 sec.
Initial velocity = 0 mm/sec
Final velocity after 0.3 seconds = approx 0 mm/sec
(Note: Acceleration values that I have mentioned are not exact but close to actual values)
Can I switch between these accelerations in that short time frame?
Which commands should I use in RAPID?
Nikhil
- 365 IRC5
- 84 OmniCore
