Movement of the robot
Hello people,
I'm trying to configure a conveyor tracking system. My question turns around the movement of the robot in robot studio versus quickteach.
When there is a conveyor tracking system robot's base frame is turned 90? respect world frame. if so, that it is true because I can check it in MOC.cfg, why If I move the robot via robotstudio/mechanismStatus" there is no difference between moving the robot respect robot's base frame or world frame? why does "X" direcction is the same one for both frames (world and base)?
If I move the robot from quickteach the movement is right! i mean that between axis "x" from base frame and "axis "x" from world frame there are 90? degrees!
What is going on?
Thank you very much in advanced,
Jordi Santisteve
Jordi Santisteve De Doria
Project Engineer
ABB
+34 937288771
If the baseframe is rotated 90 deg. in the VirtualController, you have
to rotate the robot model in RobotStudio 90 deg. The reason is that the
robot model must match the baseframe in the VC. When you rotate the
robot, use Modify-Rotate or Modify-Position, do not use Modify-Position
Robot World.
Thank you very much Anders, now it is time to simulate conveyour tracking and translate programs from tralfa to IRB5400! If I have problems I will post these.
Thanks and best regards,
Jordi Santisteve
Project Engineer
ABB
+34 9372887710
- 858 RAPID Programming
