Smart Components Disappearing
in UpFeed
I have had a problem in version 5.15 with smart components disappearing from a smart component group.
I had 4 smart component groups each containing 10-20 smart components linked together and when i went to run the simulation I got no response back from the objects i expected to move, only to find that a number of smart components had completely disappeared. In one group the first 3 components had disappeared out of 10 and in a second component 8 components had disappeared out of around 20.
I am not sure if this is happening during testing or construction of other smart components or if this happened during saving then loading of the project as I only noticed this when starting the simulation after loading the project and then applying some changes
Hi Simon,Please get in touch with your local ABB Robotics Service representative that can forward your issue to our tech support (see http://www.abb.com/contacts). See here for how to proceed.Henrik Berlin
ABB0
- 367 IRC5
