Flexible hose addin
Is there a flexible hose addin for RS 5.15
This is required for just for visual effect
  • Would also be great to use to see if the hose/cables might be entangled in anything :)
    Best regards
    Alexander Källberg
  • I recently uploaded our old prototype on RobotApps. It is limited in functionality so don't expect too much.
    ABB
  • Hi
    The hose AddIn looks good. I could create new hoses in the IRB6640_DressPack Station, but I could not create a new hose in my own station. I couldn't find any Type Names in the Properties. Where can I get those types from and where do I have to put them in my station.
    Best regards
    Marcel
  • You need to type in a name yourself. There is no default material type name.
    ABB
  • Hi Henrik
    Thank you, now it works. Smile
    Best Regards
    Marcel
  • Its not working on my system, if i unzip the files to the directory given in the pdf instruction the RsHose will not appear when i open robot studio
    there are also DLL files in the unziped files, do in need to manualy put them somewere?
    i have tried to put them in the directory where all the other addins are defined and then the RsHose adding wil be there only ist not highlighted blue as in the PDF instruction
    dit i miss something?
    jasper2013-03-22 09:21:09
  • You need to put the .dll-files directly into the Addins folder, not in the subfolder.
    ABB
