Dispense
I have a programa done with Dispense Option, and In the simulation with RS5.15 i can't see the paths with the instructions DispL , DispC,.... in the station created.
How I can view this paths?
  • Hi,
    To see program in graphics you need to sync the program from VC to RobotStudio. You also need to set up instruction template manager with the needed instruction (se example picture): BR / Henrik
    Kga Offline Center www.kgaofflinecenter.se
    Offlineprogramming and simulation in RobotStudio and ArcWeld PowerPac
  • There are pre-defined instruction templates for Disp-instructions installed with RS. Use the 'Import' function of the Instruction Template Manage and select the file Disp.xml.
    ABB
