debug FP app. on virtual controller SDK 5.15
I was a problem about debug FP application on virtual controller using Virtual FlexPendant of Robostudio online 5.15. In older version all work good, but in the latest version virtual FP is not in maganged code by VS2005 and not load any symbol about my application.
Why it? where is the wrong if for example on Robostudio online 5.14 I do it without problem?
best regards ema
best regards ema
It is the sad fact that .Net moves on while Compact Framework stands still. So while RobotStudio and the Virtual Controller moves forward on the new platform it is no longer possible to connect directly with it Visual Studio 2008...Check out the workarounds in the release notes.http://forums.robotstudio.com/forum_posts.asp?TID=7140John
Developer Center0 -
thank you very much about your notice.. :-(
Found this post, since it seems, that I've the same problem (cannot debug my 5.15 FP app any more after upgrading from 5.14). Unfortunately the link with the workarounds is not working any more. Can anyone post this workarounds?
