Dispense
esxamar
I have a programa done with Dispense Option, and In the simulation with RS5.15 i can't see the paths with the instructions DispL , DispC,.... in the station created.
How I can view this paths?
Hi,To see program in graphics you need to sync the program from VC to RobotStudio. You also need to set up instruction template manager with the needed instruction (se example picture): BR / Henrik
Kga Offline Center www.kgaofflinecenter.se
Offlineprogramming and simulation in RobotStudio and ArcWeld PowerPac0 -
There are pre-defined instruction templates for Disp-instructions installed with RS. Use the 'Import' function of the Instruction Template Manage and select the file Disp.xml.Henrik Berlin
ABB0
- 367 IRC5
- 858 RAPID Programming
