enabling world zone in multitask system
What do you mean by 'gets stuck'? Do you get any messages in the controller event log?Do you have the RobotWare options for Multitasking and World zone in your controller system?(Moved to RobotWare)Henrik Berlin
Yes I have that options already installed...I mean the program pointer stops at WZDOSet code and stops running showing the following error:40813: Execution ErrorDescriptionTask: MergedTaskThe task is not allowed to execute the instruction WZDOSet.Program Ref. /MergMod/wz_conv/WZDOSet/29CausesThe task is not configured to control mechanical units.ActionsChange the configuration or removeSo does this mean semistatic or static tasks can't define world zones?R&D Electronics Engineer0
You have to define the WorldZone in the main task where the mechanical units are defined. But you could set a virtual signal with the WorldZone in the main task and to activate the signal you could set a second virtual signal and crossconnect them in the EIO.cfg to get the needed output signal.Best RegardsMarcel0 -
Hi Marcel,I have two robots which have common work area. In manuel mode when one robot occupies the common zone, the other robot shouldn't be let in that area even by manual jogging.In manual mode main task is not operational. So eventhough I send signal from the static task to activate the worldzone defined in the main task, it won't be enabled. Do I miss something?Erhan KU?zR&D Electronics Engineer0
Hi Erhan <?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
I am not sure if I understand you correct.
Once you have defined the world zone to set an output, the signal will be set also in manual mode. So you could decide in the background task what to do with that signal. For example you could set an output that would stop on of your robots by setting a system input for stopping the robot.
Best regards
Marcel
Marcel,The problem is that. I don't want to disable the robot movement which is out of the common workzone. When one robot enters the common workzone, the other robot shouldn't enter that zone but it could still move outside the common workzone. How could I achieve this?Thanks in advance. Best regards.Erhan KU?zR&D Electronics Engineer0
We once realized a solution with two robots, each of them setting a free signal. IF both signals go to 0 the robots will be stopped from the background task. Movement was only possible in manual mode and only up to a distance of 100 mm from the stop position. After 100 mm it was possible to start again after releasing the enabling switch and pressing it again.
Best regards
Marcel
- 364 IRC5
- 82 OmniCore
