Robotstudio hangs unexpectedly
DanLars
Hey all,
I'm currently developing some semi-automatic welding add-in and I have noticed a rather unexpected behavior when I have to find configurations for a number of targets.
The problem is worst when a external manipulator is selected. When no manipulator is selected I can, atleast sometimes, create 10000 targets with a random XYZ position between 0-1 and iterate through them all to find out if there is a valid configuration or not for each of them.
But if I select a manipulator, it can barely do 50 targets. What I experience is that the method that I'm calling returns fine, but when Robot Studio enters its mainloop it get stuck in a wait, in the threading part of mscorlib - see two stack traces below (find by pausing code execution).
mscorlib.dll!System.Threading.Monitor.Wait(object obj, int millisecondsTimeout, bool exitContext) + 0x16 bytes
... mscorlib.dll!System.Threading.Tasks.Task<RobotStudio.Services.RobApi.RobControllerOperatingMode>.GetResultCore(bool waitCompletionNotification) + 0x20 bytes
mscorlib.dll!System.Threading._ThreadPoolWaitCallback.PerformWaitCallback() + 0x5 bytes
[Native to Managed Transition]
And the other:
RobotStudio.Services.RobApi.dll!RobotStudio.Services.RobApi.RobControllerConnection.TrySendCommandOnCurrentThread(string cmd, string url, string prop, string args) + 0xd9 bytes
RobotStudio.Services.RobApi.dll!RobotStudio.Services.RobApi.CollectionHelper<RobotStudio.Services.RobApi.RobSymbol>.GetItems.AnonymousMethod__0(System.Threading.Tasks.TaskCompletionSource<RobotStudio.Services.RobApi.RobSymbol[]> tcs, System.Collections.Generic.List<System.Action> _) + 0xff bytes
RobotStudio.Services.RobApi.dll!RobotStudio.Services.RobApi.TaskUtils.Run<RobotStudio.Services.RobApi.RobSymbol[]>.AnonymousMethod__0() + 0x8d bytes
It seems that the virtual controller is not responding and hence Robot Studio just hangs and the only thing to do is to force it to close (stop debugging / terminate process).
I hope a solution can be found - either by you, or corrections to my use of the API.
I have attached a VS2012 project that implements the required methods to test this and I have also attached a pack&Go with a robot and two manipulators.
Lars Glud
Danrob A/S
Danrob A/S
Hi Lars, I have downloaded the project and will take a look at it.
Niklas Skoglund2013-02-17 19:01:420 -
You are writing that "When no manipulator is selected"... do you mean selected like selected in the tree view? In your addin I only found one button, so there is nothing to select there. Right?0
OK - if I activate for example STN_1 in your station I can reproduce the problem.It hangs after the button event handler has returned.A work item has been created, and a PDD by the support team.0
Thanks a lot for looking into it, Niklas
Lars Glud
Danrob A/S0
- 365 IRC5
- 84 OmniCore
