PCSDK: Exception when using MainComputer
sanderb
Hi All,
when I try and access the contollers MainComputerServiceInfo I get the above exception, with the message "The URL used to initialize the helper does not resolve to a valid object."
Obviously I'm doing something wrong.
What I do is (I've shortened it):
var scanner = new NetworkScanner();
NetworkScanner.AddRemoteController(ipAddress);
scanner.Scan();
ControllerInfo[] controllerInfos = scanner.GetControllers();
robotController = ControllerFactory.CreateFrom(controllerInfos[0]);
robotController.Logon(UserInfo.DefaultUser);
Now I have a connection to my robotController, testing it with the following code creates a perfect backup, so the controller works.
var backupManager = new BackupManager(robotController );
backupManager.LocalName = systemName + ".lzo";
backupManager.Backup();
When I call
MainComputerServiceInfo infCPU = robotController .MainComputerServiceInfo;
OR
string str = robotController .MainComputerServiceInfo.CpuInfo;
Gives me the above error.
Does anybody knows whats going wrong? A piece of sample code perhaps?
Exception details:
ABB.Robotics.GenericControllerException was unhandled
Message= The URL used to initialize the helper does not resolve to a valid object.
Source=ABB.Robotics.Adapters.IRC5
ExtendedErrorInformation=""
StackTrace:
at Adapters.Data.Get()
at ABB.Robotics.Controllers.Internal.DAL.DataAccessObject.GetStringValue(String instance, String attribute)
at ABB.Robotics.Controllers.Internal.DAL.MainComputerDevice.GetCpuTemperature()
at ABB.Robotics.Controllers.Internal.Controller.GetMainComputerServiceInfo()
at ABB.Robotics.Controllers.Controller.get_MainComputerServiceInfo()
at AWL.RobotController.AbbController.GetCpuInfo() in c:UserssboDocumentsVisual Studio 2012ProjectsRobotStudioAddin1AbbControllerAbbController.cs:line 57
at WindowsFormsApplication2.Form1.button1_Click(Object sender, EventArgs e) in c:UserssboDocumentsVisual Studio 2012ProjectsRobotStudioAddin1WindowsFormsApplication2Form1.cs:line 26
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.Run(Form mainForm)
at WindowsFormsApplication2.Program.Main() in c:UserssboDocumentsVisual Studio 2012ProjectsRobotStudioAddin1WindowsFormsApplication2Program.cs:line 18
at System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args)
at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
InnerException:
John Wiberg2013-02-22 15:53:00
Replicated. Can't get it to work either and I get the same error.I have reported this to R&D as a bug.John
Developer Center0
