how to add options to already built in system
xeratule
Hi all,
In robotstudio -> controller -> Edit System
I see the system configuration. When I click add button I can't find options.
xeratule2013-03-01 09:01:17 Erhan KU?z
R&D Electronics Engineer
0. Take a backup of your system.
1. Shutdown the system
2. Open system builder
3. Select the system and choose Modify
4. Add the options you need and close System Builder
5. I-start the system to activate the new options.
6. Restore the backup.
7. Done!
Thank you Henrik that worked.Erhan KU?zR&D Electronics Engineer0
