RS station can't opened!!!
Linda
Hello, I met a problem that can't open the RS station.
I don't know why. And here is the error information.
Pls help to fix this.
Thanks a lot!
the error log
I usally get this error when i have made an faulty adjustment in RS, after synchronizing to the VC this error appears and you can't go back and change your faultThe best thing to get it working again is to start an new station with an empty rapit editor screen and than open your last saved station again.Your empty rapid editor screen will (in my case) get rid of the error and you can change your last adjustments what probaly coused your error to appear.Hopes this helps
jasper2013-03-06 10:26:060 -
The first thing to test is to upgrade to version 5.15.00.01 as you are running 5.14.02. You can reach the download link from here. You can use 5.15.00.01 side by side with 5.14.02 and the license is the same. Just install and run it.
ABB1 -
Thanks a lot! I tried the version 5.15 and the station can be opend now, even still can't start the virtual controller. Lucky that I can save my trajecotry and trasfer to another new station.
But what do you mean by "empty rapid editor screen"? A new empty station?in 5.14 version or 5.15 version?0 -
In robot studio 5.14 the tap is called ''Offline''In version 5.15 the tap is called ''RAPID''but if you can open your station you can undue your last adjustments and hopefully will be able to get it synchronised again, if not please screenshot the errors you get.0
- 344 IRC5
- 70 OmniCore
- 842 RAPID Programming
- 19 AppStudio
