Proc with argument
Hello
I have mulitple programs wich are all the same but just changing one number
    PROC MoveToPos1()
        SetDO DoMoveToPosition1,1;
        WaitDI DiPosition1,1;
        SetDO DoMoveToPosition1,0;
    PROC MoveToPos2()
        SetDO DoMoveToPosition2,1;
        WaitDI DiPosition2,1;
        SetDO DoMoveToPosition2,0;
I want to replace them with a single proc with an argument, something like this:
    PROC MoveToPos(num Position)
        SetDO "DoMoveToPosition"+NumToStr(Position,0);,1;
        WaitDI "DiPosition"+NumToStr(Position,0);,1;
      SetDO "DoMoveToPosition"+NumToStr(Position,0);,0;
This doesn't work and gives me a type mismatch error. I've tried also with the StrToVal function, but it doesn't work either.
Is there any way to do this?
Thank you
  • Try this:
    %"SetDO DoMoveToPosition"+ValToStr(Position)+",1"%;
    %"WaitDo DiMoveToPosition"+ValToStr(Position)+",1"%;
    %"SetDO DoMoveToPosition"+ValToStr(Position)+",0"%;
    Hope it will work out.
    blind3rr
    blind3rr2013-03-11 01:46:47
    Benteler Maschinenbau CZ
  • [QUOTE=londoneye]Hello
    [/QUOTE]
    The ; shoudn't be inside the calls - only at the end.
    Try remove them.
     Just looked a bit further into it - you can't give SetDO etc. a string as it expect a type of signalDO.
    Mayby this approach can be used?
            TEST Position
            CASE 1:
            CASE 2:
            DEFAULT:
                TPWrite " No such position exist";
                Stop;
            ENDTEST
    Regards, Lars
    DanLars2013-03-11 10:11:45
    Lars Glud
    Danrob A/S
  • [QUOTE=blind3rr]
    Try this:
    blind3rr
    [/QUOTE]
    It gives me this error
    40226: Name error
    Description
    Task T_ROB1: Procedure name
    SetDO DoMoveToPosition3 1
    is not a RAPID identifier excluding
    reserved words
    Actions
    The procedure name, must be a legal
    RAPID identifier not equal to any of
    the reserved words of the RAPID
    language. Change the name expression.
    What is % supposed to do anyway?. I cannot find it in the manual?
  • [QUOTE=londoneye]
    [/QUOTE]
    A text string encapsulated in % will be called as if it where at PROC. Like this:
    PROC main
    var num path := 1;
    %"path" + NumToStr(path,0);% // Calling path1
    path := 2;
    %"path" + NumToStr(path,0);% // Calling path2
    PROC path1
    PROC path2
    As far as I can remember :)
    Regards, Lars
    Lars Glud
    Danrob A/S
  • AlexK
    AlexK ✭✭
    Something that would work is to use GetDataVal, for example:
    PROC
    MoveToPos(
    num nIO)
    VAR string strInput;
    VAR string strOutput;
    VAR signaldo ioOutput;
    VAR signaldi ioInput;
    VAR string nuStr;
    nuStr := NumToStr(nIO, 0);
    strOutput := "DoMoveToPosition" + nuStr;
    strInput := "DiPosition" + nuStr;
    GetDataVal strOutput, ioOutput;
    GetDataVal strInput, ioInput;
    Set ioOutput;
    WaitDI ioInput, 1;
    Reset ioOutput;
    The call would look something like this:
    PROC main()MoveToPos(1);
    MoveToPos(2);
    MoveToPos(3);
    MoveToPos(4);
    AlexK2013-03-12 10:44:42
    Best regards
    Alexander Källberg
  • [QUOTE=AlexK]
    PROC
    MoveToPos(
    num nIO)
    VAR string nuStr;
    Set ioOutput;
    WaitDI ioInput, 1;
    Reset ioOutput;
    MoveToPos(2);
    MoveToPos(3);
    MoveToPos(4);
    [/QUOTE]
    That worked!!!!
    Thak you very much
  • AlexK
    AlexK ✭✭
    Your welcome, glad it worked!AlexK2013-03-18 12:08:48
    Best regards
    Alexander Källberg
