Interrupt command
Paramin
Hello all,
Could anyone please help me on using an interrupt command. What I want to do now is quite a simple task in which a robot is commanded to move from P10 to the position reg (or P20). When the robot is interrupted and the reg is replaced by P30, then the robot has to move along to P30 directly and stop the process (never returns back to P20) as illustrated in the following Fig.
Previously, I have done a program using the interrupt but when the robot was interrupted, it moved to P30 correctly and went back to continue moving along the path to reach the P20 before stoping the process.
Thank you in advance.
Regards,
Paramin
Paramin2013-03-25 15:41:09 1
Did you try to use the instr ClearPath?
ClearPath
clears the whole motion path on the current motion path level (base level or
StorePath level). With motion
path, meaning all the movement segments from any move instructions which have
been executed in RAPID but not performed by the robot at the execution time of ClearPath. The robot
must be in a stop point position or must be stopped with StopMove before the instruction
ClearPath can be executed.0 -
Hello JyrgenThank you for your kindly advice; Let me try it.Thank you againParamin0
Hello to everyone,
i'm sorry for resuming such an old discussion, but i'm stuck with the same problem:
I managed to solve the problem in two ways, but both of them give me some trouble:
1) Move with \Conc:
The Move instruction is set with the \Conc option. The interruption is made by an input signal and activate a trap:
PROC main()
! Move to P2 (1)
TRAP moveAway
StopMove \Quick;
StorePath;
! Movement
StorePath;
ClearPath;
StartMove;
ENDTRAP
The tool moves from P1 to P2, gets an interrupt, moves to P3 and is able to move to another location given by an external software.
The problem with this solution is the limit of 5 continous input movement that robotstudio is unable to handle.
Without the \Conc parameter the PP get stuck at the first move (1) after the end of the trap. (it's not able to recieve other input from the backgroud task)
2) The ExitCycle option:
The "move to P2 instruction" is written without the \Conc option and, inside the TRAP, is added an ExitCycle command:
TRAP moveAway
StopMove \Quick;
StorePath;
! Movement
StorePath;
ClearPath;
StartMove;
ExitCycle;
ENDTRAP
This solution is perfect ONLY IN CONTINOUS EXECUTION MODE so is not applicable to every possible scenario.
Did you managed to avoid the problem in other ways?
Thank you Sorry for my english!2
- 345 IRC5
- 73 OmniCore
- 843 RAPID Programming
- 20 AppStudio
