Search/List loaded modules
Is there a way to search by name or view a list of the loaded modules and/or access said list through RAPID?
I can check for modules that have files on the robot drive, but if they were created on the teach pendant, there is no file.
Thanks!
Dear Alyssa,
I have a similar problem. I found only the ModExist-Command which allows to verify whether a module is loaded or not. However I would like to extend your question. Is there a way to get a list of the PROCS which are related to a certain module? E.g. something like GetNextSym?
Regards
Tobias
- 365 IRC5
- 84 OmniCore
