External Axis Wizard Guide/Usage
Is there a guide for the external axis wizard (EAW)?
I'm currently trying to get a robot to work with an external axis but I can't get it to work. I've attached the first error message to this post.
As a small side question: Does RS save your station each time you restart the VC?
Thanks in advance,
Leo
ABB1
Hi WindesheimStudent,You need to add drive unit for each additional axes you use.Erdem Karaçeper0
Ah yes. Thank you for your quick and elaborate response!0
HiYou need to add a drive module to the controller using system builder.Per Svensson
Consat Engineering0
- 344 IRC5
- 71 OmniCore
- 842 RAPID Programming
- 19 AppStudio
