RAPID: Remove a directory with contents
How can I delete a directory on the hard drive without first navigating through every subdirectory and deleting the contents?
Specifically, I am trying to delete a backup folder and all its contents.
Have you tried using the File Transfer tool in RobotStudio? There you can select a directory and choose "Delete" from the context menu. All its content will be deleted including subfolders.Henrik Berlin
ABB0
