I can't see my new topic
Hello, i dont know if i'm at the right spot to report this but i have made a new discussion topic in powerpac and put the category Arcweldpowerpac to it and now its gone
I found out that its not in the powerpac topics (were its belongs i gess) but its send to a section in this forum were i can't normally reach it.
Dit i do something wrong here or is it not working properly?
gr. jasper
Hi Jasper, I will look into it.0
Hi again,
let me first explain that we have merged all the individual PowerPac forums into one forum called "PowerPacs". The activity in a few of the forums was not high enough. Each invividual discussion can be tagged with for example "Paitning PowerPac" or "ArcWelding PowerPac".
So... coming back to your problem... when searching for your losts posts, I found that the old "RS ArcWeld PowerPac" forum was still around, and it seems like you have made your posts there.
I have moved them to the PowerPacs forum.
Is one of those, the discussion you are looking for?
http://forums.robotstudio.com/discussion/7924/loss-of-configuration-after-reloading-modules-from-robot-to-robotstudio5#latest
http://forums.robotstudio.com/discussion/7841/duplicated-search-instructions-in-rapid-editor-arcwelding-powerpac#latestWe will remove the "RS ArcWeld" forum.
thank you, its the one that was lost
its working now
Great to hear! And I have removed the old RS ArcWeld forum.
- 858 RAPID Programming
