When recording a simulation for Station Viewer does not work.
When recording a simulation for Station Viewer does not work. You can see my video.
Case A) Record from the button Simulation-> Record to viever
It always creates a file dated 28/01/2013 and size 1006 KB empty of contents.
Case B) Record from Share -> Save Station to viewer
Create a file containing the design of the station, but the simulation is not active.
Tested on different computers with 5.15.0 and 5.15.1
Finally a question: If it worked correctly Is there any difference between recording Record to Viewer and Save Station to viewer? What do you mean by "any recorded simulations"?
