SC with mechanisms and system external axis
Lin
The SC contains one mechanism.
Will the mechanism can be visible to the system to configure as a external axis?
Lingaa
As long as the MechanismType of the mechanism is correct, it should find it.
However since the SC itself isn't a Mechanism you should have opened it in the station before starting the controller so that you can point it out as exisisting in the station.
John
Developer Center0
