Axis 1 to +-180°
If I set in the configuration of my IRB6640 the upper join bound to 3.14 and the lower joint bound to -3.14, and after restart I try to jog, I can only jog +-170°.
The mechanical stops are removed, so there is no mechanical limit.
Are there other setting to be done to turn axis 1 +-180°?
