stop and execution RAPID program via PCSDK?
Hi lubosko,
I recommend going through the developer center's getting started etc.
http://developercenter.robotstudio.com/DevCenter.aspx?DevCenter=RobotCommunication
Most of what you are asking for is covered in the [Developing Controller applications] chapter of the application manual.
http://developercenter.robotstudio.com:80/Index.aspx?DevCenter=RobotCommunication&OpenDocument&Url=../RobotCommunicationAppManual/Custom/DevelopingControllerApplications.html&OptTitle=Developing Controller applications
Attached is a small sample of a basic scan + start production that I threw together a while ago. In that you can also see some of the conditions etc (mastership & logon).
How to find out if motors and safety is ok is by the controller.operatingmode property, you can also subscribe to the Controller.OperatingModeChanged event to see when it changes.
John
Developer Center0
- 365 IRC5
- 84 OmniCore
