Offset, Axis Offset, Rel Tool, or...?
Hello, need some programming advice. Equipment: Shaft located horizontal and rotated on external axis (head stock). Application: Build up several inches (in length) of shaft diameter by welding. I am trying to offset my ArcStart point for each new weld bead. I have tried all of the offsets and combinations but nothing seems to work the way I need it to. I need to weld 360 degrees around shaft, then move torch in x direction for next pass without stopping rotation or breaking arc. I have done this using several ArcL points but this becomes way too complex if I ever need to change 1 point.
Any suggestions would be much appreciated,
Adam
Hi Mr Henrik Berlin
For Conveyor Tracking Application, sometimes we need to adjust Rx, Ry and Rz. (R = Reorientation) and not just adjust offset x, y and z.
Is "Rel Tool" the only solution for this case?
If we look at Pickmaster-3 RAPID, It use Rel Tool on Pick and Place (tracking).
fear of GOD is the beginning of wisdom0
- 365 IRC5
- 84 OmniCore
