[RobotStudio SDK] Creating Faces
Hi HM,
it is not possible to create a Face directly using the API. RobotStudio has limited modeling functionality, and there are more APIs for traversing a geometry than creating one.
There are APIs that corresponds to the create functions on the Modeling Tab.
For example [URL=http://developercenter.robotstudio.com:80/Index.aspx?DevCenter=BlobProxy/devcenter/RobotStudio&OpenDocument&Url=html/7ff81eb9-9c74-30c7-0c64-f854e424c274.htm&OptTitle=CreateSurfaceCircle Method ]CreateSurfaceCircle Method [/URL]
Hi HM,
What is it that you are trying to accomplish?
In RobotStudio the Face object cannot exist on its own, instead it is always "inside" a body. So while you cannot create a face on its own you have lots of ways of generating surfaces (Face) which you can then use.
For example, I want to break up a solid object into its faces. Then I could take each individual face and put them in a seperate body. Like this:
// Check that we have an active station
Station _station = Project.ActiveProject as Station;
if (_station == null) return;Project.UndoContext.BeginUndoStep("TheBoxYouOpenedItWeCame");
try
// Create a part to contain the bodies.
Part p = new Part();
_station.GraphicComponents.Add(p);// Create a solid box.
Body box = Body.CreateSolidBox(new Matrix4(new Vector3(0, 0, 0), new Vector3()), new Vector3(1, 1, 1));
foreach (Face i in box.Faces)
p.Bodies.Add(Body.CreateFromFace(i));
catch
Project.UndoContext.CancelUndoStep(CancelUndoStepType.Rollback);
throw;
finally
Project.UndoContext.EndUndoStep();
}John
Developer Center0
