Convert Euler angles to quaternions
Simotion
For my tool I need to setup the correct rotation.
I know the angles to rotate, but in the toolconfiguration it needs to quoterinions.
I found a handy online tool for convertion, Euler -> Quotertnions, but onsit I have no internet, so does someone has knowledge of
a small desktop program that can do the conversion?
1
I have created Excel macros for conversion between quaternions and RPY (=EulerZYX) angles. Please let me know what you think.Henrik Berlin
ABB1 -
I tried to open the xlam file with Excel 2010, but I see nothing??
It's the other file you need to open, and you need to extract both files as the document will reference the xlam file. Also need to activate the macros. Works great!
Best regards
Alexander Källberg0 -
I am working on a project involving conversion between Euler and quarternian angles, I am having a little problem with the spreadsheet, when I try to enter values into the initial values [deg] fields, the updated converted q values, and converted verification values come up with "#NAME?"Any ideas?0
