Copy virtual robotstation
Simotion
I have setup a virtual robotstation with simulation and smartobjects.
Now I want to make a copy of it, but I think that the copy will stil work with the same system, so if i make changes in the system,
my original system will change also. What do I need to do if I want to start from the original station, make a copy of it, but do not want to influence my original
station, only my copied one?
make a pack and go, everything should be included in this file.FILE=>SHARE=>Pack and GoWhen you open it, a new controller and station are made in the location you want.RobWelding
The Netherlands0 -
Thanks!0
