digital camera ABB commnication
Is it possible to send command to a normal digital camera using RobotStudio? All I need is to automatically trigger the shutter when the robot arm is in desired position.
  • If your digital camera has a trigger input, you can wire it to a discrete output from the robot controller i/o.
    Make sure the voltages are compatible.  If they are not (for example, the controller i/o may be 24vdc and the camera trigger may be 12vdc) then use an isolation stage, like opto-isolator is a good choice.
    Also pay attention to the camera's trigger-state.  It is common for the trigger to operate in different modes, depending on camera settings.
    If the trigger is rising edge active, the one example of RAPID would be; Reset Camera_Trigger; PulseDo \High \PLength:=.03, Camera_Trigger;
    image   M. McGraw
    <font face="Verdana, Arial, Helvetica
  • Thanks for your comments. I will it a try.
